News 4 PC parts you should never skimp on
When it comes to core components, it pays not to cut corners.
Image: Thomas Ryan/IDG
Summary created by Smart Answers AI
In summary:
  • PCWorld identifies four critical PC components where quality investment is essential: power supplies, RAM, monitors, and NVMe SSDs.
  • High-quality power supplies prevent system crashes and hardware damage, while superior RAM with low latencies and good NVMe SSDs significantly boost performance.
  • Quality monitors with IPS or OLED technology provide better resolution and color accuracy, ensuring long-term system stability and user experience.
When buying a PC, it can make sense to save money in certain areas. However, when it comes to core components, choosing the cheapest option rarely pays off. Here, quality is not only a factor in performance, but also in stability, durability, and everyday convenience.
A high-quality power supply, for example, is the foundation for a reliable system. Cutting costs here can lead to unstable voltages, system crashes, or (in the worst case) damaged hardware. Good power supplies deliver clean voltages, operate quietly and efficiently, and have protective circuits. This is especially important with power-hungry graphics cards and processors; a certified model (e.g. according to 80-Plus or Cybenetics standards) with sufficient power reserves is a must.
When building your own PC, the following applies: if you cut corners on essential components such as RAM or SSD mass storage, you risk stability problems and a shorter service life for your assembled computer.
HP
It also makes sense to invest more in a monitor. Cheap displays often skimp on resolution, refresh rate, or color representation. Anyone who works, plays games, or edits images will benefit from a higher-quality panel, such as IPS or OLED. This forms the basis for a sharp display, smooth playback, and accurate colors. In addition, a good monitor will usually last for several PC generations, making it a long-term purchase.
When it comes to power supplies, cooling and graphics cards, you shouldn’t cut corners: quality is key to stability and longevity.
Cooler Master
When it comes to RAM, you should opt for proven modules with good compatibility–meaning tested support for your motherboard and CPU, as well as solid timings such as CL16 or CL18. In practical terms, this means checking whether the modules are approved via the motherboard manufacturer’s QVL (Qualified Vendor List).
At the same time, look for low latencies to achieve noticeably better performance in games and applications. No-name offers are often risky, as modern platforms react noticeably to RAM speed–both in gaming and in productive workloads. Here, quality directly translates to performance and stability.
A high-quality monitor is ahead in terms of image sharpness, response time and colour fidelity. You can see the advantages every day. It’s worth spending a little more money.
Viewsonic
Mass storage also deserves attention, as SSDs significantly speed up the entire system. However, cheaper models often offer lower durability and poorer write speeds. A solid NVMe SSD with a reliable controller is the better choice and helps ensure a fast and responsive system in the long term.
You should also pay attention to the PCI Express connection–at least PCIe 3.0, preferably PCIe 4.0 or 5.0–and the M.2 form factor. This allows higher speeds than SATA and integrates the flash memory directly into the motherboard in a space-saving way.
It is better to save on easily replaceable components such as the case or optical extras. When it comes to the power supply, monitor, RAM, and storage, however, you should focus on quality, as these components determine how stable, powerful, and future-proof your PC really is.
This article originally appeared on our sister publication PC-WELT and was translated and localized from German.
Author: Friedrich Stiemer, Contributor, PCWorld
Recent stories by Friedrich Stiemer:
