Adobe is building AI agents for Photoshop and Premiere Pro that can suggest ways to edit your photos or videos and then carry out the tasks for you, according to a blog written today by Ely Greenfield, Adobe’s CTO of digital media.
Adobe Photoshop’s agentic AI, or what the company calls its “creative agent,” will be presented in a new floating Actions panel that will recommend context-aware edits after analyzing your photo. For instance, it will be able to suggest removing people standing in the background or creating a greater depth of field by blurring everything behind the subject. All you need to do is click the suggestion and it will be carried out automatically.
Long-time Photoshop users are used to manually manipulating photos by tediously masking people and objects and then creating layers so changes can be made to only certain parts of the image. Adobe has already added AI features that let you extend and fill photos across a larger canvas, or delete unwanted objects or people from the background using Distraction Removal.
Adobe’s vision is that Photoshop users will be able to prompt agents with natural language, making it easier to learn the steps needed to perform a task (although the agent will still be able to do it for you). And you can continue prompting the agent to make more changes, or manually make adjustments in the layers. In one example video, someone asks the agent to clean up an image and add a text box behind a person, and the agent then lists out steps including: remove background people, auto brighten, remove distracting objects, create “subject” layer, create text layer, and organize layers.
For Premiere Pro, Adobe will build on the new Media Intelligence feature introduced last week, which analyzes videos for objects and composition so you can find the footage you need. A future agent will let you direct the agent to make a rough video cut.
“While AI can’t replace human creative inspiration, with your input it can make some educated guesses to help you get your project off the ground,” Greenfield wrote in the blog. “It can also help you learn how to perform complex tasks with a few simple keystrokes, helping you grow as an editor.” Premiere Pro’s creative agent will eventually help editors refine shot choices, adjust color, mix audio, and more. Adobe also just launched Generative Extend, which uses AI to add seconds to your clips to help fit a transition.
Adobe will introduce the technology behind the first AI agent, which will be for Photoshop, at its Max event in London on April 24th.
