Обзор All battery Ring Doorbell models plummet to record-low prices!
Обзор
15 Февраль 2018
All of these offers are available from Amazon, which owns the Ring brand. The good news is that they are all “limited time deals.” This means the discounts are automatic, and you don’t need to be a paid Amazon Prime member. Just add it to your cart and check out!
Ring Battery Doorbell
I personally own this model, and while it isn’t as good as the higher-end ones, it works great for my needs, and I didn’t have to spend much on it. Lucky you! You’re getting it for less than me!
The Ring Battery Doorbell offers a nice 1,440p resolution, which looks great, especially considering its main job is to record people pretty close by. The lens has a wide 150-degree field of view. According to Ring, this offers a “head-to-toe” view of people. This is primarily true as long as the person isn’t very close to the camera. Once they are right in front of my camera, it is more like head-to-knees. Still good enough to get a good view of what’s going on, though!
Other features include night vision, two-way audio, quick replies, package alerts, Alexa support, and more.
My only real complaint is that this model doesn’t have a removable battery. But hey, it is only $49.99! I also don’t have to charge it very often, usually about once every four months or so. This requires pulling it out of its dock and plugging it in via USB-C.
Also, keep in mind that most features require a paid Ring Home subscription. Without a paid subscription, you’ll only get live view and motion alerts. You can learn more about Ring Home plans and prices here, but they start at $4.99 monthly.
Ring Battery Doorbell Plus
The Battery Doorbell Plus merges features from some of Ring's better products.
This 2023 Ring doorbell model offers 1536p resolution, and a 150-degree view both vertically and horizontally, which aids with person and package detection.
If you want a better experience, the Ring Battery Doorbell Plus is a nice upgrade, and it’s currently only $30 more. It will get a higher 1,536 resolution and the same 150-degree field of view. Another significant upgrade is that this one actually comes with a removable battery! You won’t need to remove the doorbell to charge it. And if you have extra batteries, there will be no downtime, as you can just swap batteries.
The rest of the experience is pretty much the same. Of course, you still need a Ring Home subscription to access most features.
Ring Battery Doorbell Pro
Now, if you want the best of the best, this is Ring’s top Battery Doorbell model. The Ring Battery Doorbell Pro is actually not that different from the Plus; it just comes with some added features.
These include bird’s eye view, improved motion detection, better audio, pre-roll recording, and dual-band Wi-Fi support. Otherwise, you’ll get the same specs as the Doorbell Plus, such as a 1,536p resolution and a 15-degree field of view.
If you feel like those additions are worth the upgrade, there has never been a better time to buy it. It is at a record-low price of $129.99!
Are you signing up for any of these? Remember, these are record-low prices. Such deals don’t last long, so go grab yours while it’s hot!
