Обзор Beats Fit Pro vs Beats Powerbeats Pro: What’s the difference?
Обзор
15 Февраль 2018
Like most electronics makers, Apple tends to nudge people towards its latest, greatest, and most expensive products. At the moment however you’re liable to be confused if you’re shopping for Beats earbuds, since the older Powerbeats Pro can potentially be more expensive than the newer Fit Pro, depending on where you’re shopping. So weighing the Fit Pro vs the Powerbeats Pro, what’s the difference, and which one should you actually buy?
Beats Fit Pro vs Beats Powerbeats Pro: At a glance
