News Best early battery charger & power bank deals for Prime Day 2024
Amazon’s Prime Day sales event is nearly here, but the early deals on chargers and power banks have already begun. This year, Prime Day will run from July 16 through July 17, and should include some great bargains. So, whether you’re looking to snag a travel-friendly pocket charger or upgrade to a high-capacity drive, there is no better time to get discounted chargers and power banks.
As a tech editor, I’ve been following and writing about the latest tech deals for years now and have a keen eye for finding the best sales from all over the internet. Right now the best early deals are coming from Amazon, but I expect other retailers to jump on the Prime Day action, as well, and will add those to my recommendations as I discover them.
My picks take into account a combination of online reviews from tech sites like PCWorld (when available), user feedback, and price history. Read on for all of the best early deals on chargers and power banks, and be sure to check out our Prime Day 2024 deals hub for more great sales across all the tech categories.
Best Prime Day 2024 early deals on chargers & power banks
Deals on portable chargers and power banks are already surprisingly good this early. The Anker 622 Magnetic Battery for $5 off on Amazon is a personal favorite thanks to its magnetic charging stand as well as its ability to fold up into a very compact on-the-go charger.
If you need something rugged and reliable that you can bring on even the harshest of adventures, then look no further than the Mregb Solar Charger Power Bank on sale for 21 percent off on Amazon. This absolute tank of a power bank can recharge without the need for an outlet thanks to its built-in solar panel, and its IP67 waterproof rating means it can be submerged in water for up to 30 minutes without damage.
Battery charger & power bank FAQ
1.
What should I look for in a portable charger and power bank?
Quality can differ greatly among power banks, so it’s best to stick to recognizable brands like Anker, Mophie, Belkin, and the like. That said, there are a few things you should always look for when shopping for a power bank.
First, make sure the battery pack is Quick Charge 2.0, 3.0, or PD certified. Next, don’t put too much confidence in a company’s claims that it can charge certain devices in a specific amount of time, such as the pack can charge an iPhone 15 in two hours. Focus more on the battery capacity, along with weight and size. Larger capacities in the 20,000 mAh or higher range should be enough for most small devices such as tablets or smartphones. Finally, make sure that the power bank comes with all of the correct connectivity options you need—USB-A or USB-C, etc.
2.
What battery capacity should I look for in a charger?
For a portable power bank that you can easily travel with, you should look for a minimum of 10,000 mAh. Most models these days even offer 20,000 mAh for reasonable prices. The more mAh, the better. Just be sure to weigh your capacity needs against the physical size of the power bank.
Generally, the more mAh a power bank has, the larger its physical size and the heavier it is, as well. Therefore, we recommend when looking at a power bank, you first consider the amount of power you need to charge your devices, and then adjust your expectations according to the size and weight you are willing to carry around with you.
3.
What is mAh capacity?
The mAh (milliampere per hour) capacity rating refers to the available storage capacity for a battery. A higher number means that the battery can store more energy and has a longer battery life when charging a device. So for example, an iPhone 13 Pro Max’s battery is rated at 4,352 mAh. This means that a power bank with 10,000 mAh can fully recharge that phone a little over twice before running out of power.
Power
