News Bose's SoundLink Max is its largest portable Bluetooth speaker with 20-hour battery life
Bose may be best known for its noise-canceling headphones, but the company makes solid portable Bluetooth speakers too. In fact, the company's SoundLink Flex made our best Bluetooth speakers list as a great option among contenders in its price range. Today, the company is adding to the SoundLink lineup with its largest portable Bluetooth speaker yet: the SoundLink Max ($399). While the overall design is similar to previous Bose devices, this model packs bigger sound and longer battery life into that expanded frame.
Inside the SoundLink Max, three transducers and two passive radiators power "a spacious stereo experience" that includes bass performance that sounds like an even larger speaker, according to Bose. The company says this portable unit employs tech typically used in its soundbars and pairs that with digital signal processing to reduce distortion for "full, natural sound" across genres. Bose is promising that you'll be able to hear every aspect of a song clearly, no matter the musical style and no matter where the speaker is located. You'll also be able to adjust lows, mids and highs via the Bose app if the stock tuning doesn't suit your preferences.
Bose
Bose opted for a powder-coated, silicone-wrapped steel enclosure for the SoundLink Max, which the company says offers a more refined look. The speaker is also IP67 rated, so dust, water, rust and dropping it shouldn't be an issue. This all makes the Max well-suited for outdoor use, and when you do take it on the go, you won't have to worry about recharging often. Bose says the SoundLink Max will last up to 20 hours, plus it can juice up your phone via a USB-C cable if needed. A removable rope handle will assist with transport, but Bose also makes a carrying strap if you prefer over-the-shoulder hauling.
The SoundLink Max is equipped with Snapdragon Sound, which offers more consistent connectivity with recent Android devices, and aptX Adaptive that provides improved audio quality over Bluetooth. The speaker also supports Google Fast Pair and Bluetooth 5.3.
Pre-orders for the SoundLink Max start today from Bose, and the speaker is schedule to ship on May 16. In addition to being the company's largest portable Bluetooth unit, it also ties the Bose Portable Smart Speaker for being the most expensive at $399. If you're looking for something smaller, the SoundLink Micro ($99), SoundLink Flex ($119) and SoundLink Mini II ($149) are also available from Bose.
This article originally appeared on Engadget at https://www.engadget.com/boses-soun...h-20-hour-battery-life-130043418.html?src=rss
