News Corsair Platform:4 review: A modular desk with powerful features
  • High-quality feel and stable Construction
  • Modular T-channel system for flexible customization
  • Quiet and efficient electric height adjustment
  • Large work surface with integrated cable tray
  • Simple assembly thanks to pre-sorted components
  • High price
  • Expensive accessories
  • Cable eyelets poorly made and difficult to mount
The Corsair Platform:4 is a well thought-out, versatile, and customizable desk system that appeals to both gamers and productive users. The workmanship is high quality, the design is clearly structured, and the modularity offers many expansion options. The table top and the stable aluminum frame system ensure long-lasting usability. The Elevate version with quiet and efficient electric height adjustment (reviewed here) makes for a long-term and flexible solution. However, it does come at a price.
1199,90 Euro
Best Prices Today: Corsair Platform:4 Elevate
Corsair
1.199,90 €
With the Corsair Platform:4, Corsair is launching a modular desk system that’s interesting for both gamers and home office users thanks to its flexibility, high-quality workmanship, and well thought-out ergonomics. The standard version of the Platform:4, which sits at a fixed height, costs $699.99. We tested the Elevate version with electric height adjustment. The desk promises a high degree of adaptability that goes beyond the basic requirements of a conventional work or gaming desk.
Corsair Platform:4 design and workmanship
The Corsair Platform:4 has a robust table top made of black laminate. If you prefer a natural look, the tabletop is also available in a light wood surface for the fixed-height model, or a dark wood for the Elevate, each at a $100 premium.
With dimensions of 47 inches wide and 30 inches deep, it is quite compact, but still offers sufficient work space for monitors, peripherals, and other accessories. The surface is pleasant to the touch and resistant to scratches and stains. Thanks to the solid workmanship, the desk shows hardly any signs of wear even after intensive use.
Friedrich Stiemer
The highlight of the design is the aluminium T-channel system, which makes it easy to attach and adjust accessories such as monitor arms or lighting. This system allows the use of numerous extensions, including customized ones, which can be retrofitted as required. In terms of stability, the Corsair Platform:4 was completely convincing in the test — even under dynamic load, the table was always stable.
Friedrich Stiemer
Assembly and scope of delivery
Corsair delivers the Platform:4 in a single large and heavy box, which requires two people for transport. In addition to the parts for the table, the package also includes a flexible monitor arm with a gas pressure spring and VESA mount.
There are also connection adapters for Elgato accessories, numerous plastic and Velcro cable ties, cable guides, cable eyelets, and a small bag with spare parts such as additional screws and T-nuts. A particularly positive feature was that the assembly materials were sorted for each assembly step and packed in labelled bags. These bags contained precise information on the number and labelling of the respective parts, which made assembly much easier. Corsair even supplies tools!
Friedrich Stiemer
The assembly itself was quite straightforward and for the most part even self-explanatory. The threads, drill holes, and materials were flawless throughout, which further emphasized the impression of high-quality workmanship. The general feel of the table should also be emphasized positively, as the surfaces appear pleasant and stable. On closer inspection, we only noticed very small imperfections in the edges — but nothing of any significance.
Precise information on the number and labelling of the respective parts, made desk assembly much easier. Corsair even supplies tools!
Friedrich Stiemer
Nevertheless, you should allow around two hours for assembly. It is helpful to have enough space available for the boxes and packing materials so that you are not hindered during the assembly process. A second person should also assist with turning over the assembled table to avoid damage and injury.
Friedrich Stiemer
There were no more problems worth mentioning when setting up the Elevate version. The cable remote control could be fitted without any problems as the screws were the right length and there were enough of them.
In other media reports on the Corsair Platform:6, there was talk of difficulties when screwing on the remote control due to the screws being too short. These problems seem to have been solved with the Platform:4. The other assembly steps went smoothly.
A tip for assembly: The cable eyelets supplied make it easier to lay the cables neatly along the underside of the table, even if there is no special cut-out for cable routing. With a little skill, all cables can still be stowed away safely. The only point of criticism: The eyelets are not only difficult to press into the holes, but are also poorly finished as there are numerous burrs on them.
Friedrich Stiemer
Functionality
The most outstanding feature of the Corsair Platform:4 is its modularity. The T-channel system enables a wide range of customizations. We fitted a table extension in the test, which extended the width of the table by a further 11.8 inches. This addition was easy to install thanks to the T-Channel system on the sides and proved to be very stable.
Corsair specifies the load capacity of the extension at 50 pounds, which is sufficient even for larger gaming PCs. However, the gaming desk is dominated by the T-channel system on the tabletop, which is primarily used for mounting monitor and microphone arms.
Friedrich Stiemer
Another positive feature is the optional perforated panel that can be mounted on the sides. Corsair supplies several hooks and brackets for this purpose, which can be used to securely hang headsets or rucksacks, for example. Users can therefore customize the desk to suit their individual needs.
Friedrich Stiemer
Electric height adjustment
The Elevate version of the table that we tested has electric height adjustment with two presets. The motors work quietly and smoothly, with a lifting speed of 1 inch per second.
Particularly practical: The height adjustment can also be used unnoticed during video conferences, as the noise level remains below 50 decibels. This ensures undisturbed use, even in noise-sensitive environments.
Friedrich Stiemer
Another highlight is the integrated cable tray, which is large enough to neatly store a multiple socket and cable bundles. Thanks to numerous attachment points for cable ties, even large quantities of cables remain tidy. There is also a coverable storage compartment with USB-A and USB-C charging ports for smaller devices. This is particularly helpful when using multiple devices, as chargers no longer need to be placed separately on the table.
Friedrich Stiemer
Monitor arm with gas pressure spring
A central element of the whole package is the monitor arm supplied. This arm is equipped with a gas pressure spring that enables infinitely variable height and tilt adjustment. Thanks to the VESA mount, the arm is compatible with monitors with a load capacity of up to 27.5 pounds. We mounted the monitor arm on the main T-rail on the top plate.
No T-nuts or screws were required here. Instead, the clamp of the arm had to be opened by loosening a screw and loosening the set screw. This adjusting screw also allows the arm to be moved flexibly sideways on the rail, which is particularly practical for optimum positioning of the monitor. Once mounted, the arm offers a high degree of stability, even with repeated adjustments.
Friedrich Stiemer
The integrated cable channels and clips along the arm are practical, ensuring neat cable routing and preventing cables from hanging down. This keeps the workplace tidy and functional.
Friedrich Stiemer
Practical use
In everyday use, the Corsair Platform:4 impressed us with its high level of ergonomics and adaptability. The tabletop offered enough space for a multi-monitor setup and additional peripherals. The ability to adjust the desk to the optimum ergonomic sitting or standing height proved to be a real advantage for longer working or gaming sessions. Users with changing working positions benefit from the flexible height adjustment.
Friedrich Stiemer
The high load capacity of up to 264.5 pounds offers enough leeway for extensive setups. Even with intensive use, the table showed no instability. Even large-format monitors or heavy audio setups could be positioned securely. The cable management proved to be useful for keeping the desk tidy and avoiding tripping hazards caused by hanging cables.
Friedrich Stiemer
Another advantage is the versatile customizability of the workstation. Users who often switch between different activities, such as creative work and gaming, can quickly change their individual configuration. The modular system also enables long-term expansion without having to replace the entire desk.
Friedrich Stiemer
