News Dyson's OnTrac headphones ditch the Zone's air purifier for 'audio-only' use
When Dyson revealed its Zone headphones in early 2022, the company had combined its air filtration expertise with noise-cancelling headphones. COVID-19 was still a big part of our lives back then, but the Zone doesn't protect you against the virus. Instead, it's meant to provide less-polluted air as you move about your day, battling things like urban toxins and seasonal allergens. However, extremely short battery life and a $949 price plagued that first model, so it wasn't really a device accessible to the masses.
Now the company is back with its first "audio-only" over-ear headphones, the Dyson OnTrac. There's no Bane-like mask or air filtration system here, just a set of noise-cancelling headphones with a decidedly Dyson design and a $500 premium price tag. Battery life is no longer an issue, and the company is touting both active noise cancellation (ANC) performance and audio quality on the OnTrac. There are also over 2,000 customization combinations for the outer caps and ear cushions, so you can change up the look at you see fit.
The design of the OnTrac headphones certainly looks like something that would come from the same company that built the V12 stick vac, the Airstrait hair straightener and the Cool air purifiers. Dyson combined premium materials with ergonomics to create the appropriate seal for audio and ANC while also keeping things comfortable. The company used aluminum, copper, nickel and ceramics for the outer caps on the ear cups and "ultra-soft microfiber" foam cushions on the ear pads. There are also "multi-pivot gimbal arms" to help increase comfort and relieve pressure. Plus, Dyson relocated the battery to the headband for better weight distribution.
Inside, the OnTrac features 40mm, 16-ohm neodymium speaker drivers that Dyson says are capable of a frequency response of 6Hz to 21kHz. That covers more of the sonic spectrum than he standard 20Hz to 20kHz range most headphones offer. The company also angled the drivers 13 degrees toward your ears for better acoustic performance. All of that combines to provide "deep sub-bass that you can feel, and clear highs at the upper end of the frequency range." Dyson promises the OnTrac will "reveal hidden detail" as well.
Cherlynn Low for Engadget
The ANC setup on the OnTrac is composed of eight microphones that Dyson says sample external sound 384,000 times a second. Those work with a custom noise-cancelling algorithm and "carefully designed internal geometry" for 40dB of noise blocking, according to the company. Battery life won't be a problem either, so long as Dyson's claims pan out. The company says the OnTrac is capable of up to 55 hours of use with ANC on, thanks to two high-capacity lithium-ion battery cells. A 10-minute charge will give you up to 2.5 hours of use while 30 minutes provides 9.5 hours (with ANC on in both cases). During that listening time, onboard playback and volume controls are handled by a "joystick" on the back edge of the right ear cup. You can double tap on the outside of either ear cup to turn ANC on or off.
The OnTrac headphones will be available in aluminum/orange, cooper/blue, black nickel and ceramic red from Dyson for $500. The replacement caps and cushions will be available for $50 for a set of two. Only a few colors will be available from other retailers, so you'll have to buy most of the options directly from Dyson.
This article originally appeared on Engadget at https://www.engadget.com/dysons-ont...ier-for-audio-only-use-040044551.html?src=rss
