News Hoto’s 48-in-1 electric screwdriver set hits a record low $70
Ideal for small and medium sized jobs, from smartphone repairs to PC builds.
Many years ago, I built my first PC inside a repurposed Gateway chassis with just a regular old screwdriver and a grounding bracelet. I’ll spare you the ugly details, but let’s just say I wish I had tools specially made for the job. If you want to avoid pain in your own projects, you should consider picking up Hoto’s 48-in-1 Electric Precision Screwdriver set. It has everything you need to pry open gadgets for fine adjustments, yet costs just $69.99 ($40 off) on sale at Amazon and Walmart. That price matches the record low from Black Friday.
The cordless electric screwdriver is a bit skinnier but longer than some of the other Hoto variants we’ve recommended, which is what you want in tighter quarters. It offers two torque speeds, allowing you to dial it up for stubborn screws or down for softly reassembling fragile items.
Among the included magnetic screwdriver bits are half a dozen options with 45mm shafts for extra reach. You’ll get 20 more 28mm bits to cover a range of common screw heads. The package also contains a variety of spudgers, picks, priers, and tweezers, along with a suction cup, a magnetic pad that doubles as a ruler, and things to help you stay grounded to protect yourself and your electronics. Everything is neatly secured in the included storage case, which also has a dedicated magnetizer and demagnetizer, plus an external USB-C port to charge the screwdriver while it’s docked.
Other deals you might like
  • Samsung just announced a blistering fast PCIe Gen 5 SSD, but if you’re buying an SSD purely for gaming, you can get by just fine and save money with the last-gen Samsung 990 EVO Plus. The 1TB model is down to $74.99 ($35 off) at Amazon, or you can step up to 2TB for $129.99 ($55 off) — both are new record lows. The M.2 NVMe drives are primarily limited to PCIe Gen 4 speeds, with read/write values of 7.2GBps and 6.3GBps, respectively. That’s still very fast for heavy file transfers and more than enough for SSD-optimized PC games to play their best. You can also install one inside a PlayStation 5 for expanded storage.
  • Prime members can get Ugreen’s MagFlow 2-in-1 charging stand for $23.99 ($36 off) at Amazon, which is an all-time low price. It has a magnetic holder for your MagSafe iPhone, but note: it doesn’t have Qi2’s 15W charging speed. That might be fine if you’re just using it as a bedside stand for overnight charging, however. The stand features a ball join that lets you adjust the viewing angle. There’s also a Qi pad in the base to charge your wireless earbuds. Be aware that the package doesn’t include the required 20W wall adapter.
  • The JBL Authentics 200 is available at a new all-time low of $199.95 ($150 off) at Amazon, Best Buy, and Walmart. The smart speaker sounds really good for its small stature, but surprisingly, it doesn’t have a battery to make it truly portable like the bigger and more powerful Authentics 300 does, which is also on sale for a record low $299.95 ($150 off) at Amazon, Best Buy, and Walmart. Both take on a retro-inspired appearance, but include modern smarts with both Amazon Alexa and Google Assistant built in, plus diverse connectivity options including Wi-Fi (supporting AirPlay, Chromecast, and the like), Bluetooth, and aux. Read our hands-on impressions.
