News Hurry! This compact power bank with built-in USB-C cable is only $20
A power bank is easily one of the most useful things you can carry on you at any time. You never know when your phone will start blinking red, and you don’t want to be caught with a dead phone while out and about, do you? Well, if you don’t have one, today’s your lucky day. Right now you can get this 10K Baseus power bank with a 50% discount on Amazon. Yep, you read that right! Just use code NROBNZA3 at checkout.
The Baseus Picogo is tiny enough to fit in the palm of your hand, which means it can slip into even the tightest pockets. The 10,000mAh capacity should be enough to recharge your phone about two times over, give or take depending on your particular model.
But the best thing about it is the built-in USB-C cable, which frees you from having to carry around a separate cord when you’re on the go. When not in use, the cable plugs right into the power bank itself and turns into a convenient handle.
With up to 45 watts of charging power, the Picogo can charge flagship phones like the iPhone 16 Pro and Samsung Galaxy S24 Ultra more than halfway in 30 minutes. And with the additional USB-C and USB-A ports, you can charge up to three devices at once. (When multiple ports are being used, the charging power is split between them.)
Never get caught with a dead phone again. Get the Baseus Picogo power bank for $20 on Amazon and enjoy the convenience of its built-in USB-C cable. Don’t forget to use discount code NROBNZA3 at checkout to score this amazing 50% off deal before it’s gone!
Save 50% on the 10K Baseus Picogo with built-in USB-C cable
Buy now at Amazon
