News InkPoster uses an e-paper display to bring art to your home
I’m not a fan of those TVs sold in picture frame surrounds that companies tell you are good for displaying art in your homes. There’s something unconvincing about using a powered, backlit screen for things you’re meant to stare at for quite a while. Can you really appreciate Turner’s Norham Castle Sunrise if you’re struggling with eyestrain after five minutes or so? Perhaps the cure for my dourness is to be found in PocketBook's new device, InkPoster. It uses a big, color e-paper display to do the same job, giving your eyes a better chance of seeing the brush strokes up close and personal.
InkPoster is a series of color e-paper displays equipped with battery packs that can be hung in your home for up to a year on a single charge. There’s no power cable, and it can be mounted in portrait or landscape orientation, depending on your taste. You’ll be able to access a library of curated art, put together by a team of “professional art consultants” and select what you want to see inside the InkPoster companion app. You’ll also be able to use it as a regular old digital photo frame, ideal for when you want to pull a masterpiece from online and display that instead.
There are three display sizes based on two different technologies, Spectra 6 and Sharp’s IGZO. The former is found in the 13.3-inch model with a 1,200 x 1,600 resolution, which packs a 14,000mAh battery pack. There’s a 28.5-inch edition with a 2,160 x 3,060 display which uses a hybrid of both display technologies. Finally, there’s a 31.5-inch model with a 2,560 x 1,440 resolution that uses Spectra 6 and is designed to be a real focal point in your home. The two larger models both pack a 20,000mAh battery, with the same promise of a year or so of running.
PocketBook hasn’t mentioned pricing yet for either the hardware or how much it'll cost to access its catalog of artwork, not to mention any sort of timeframe for when you'll be able to hang this on your wall.
This article originally appeared on Engadget at https://www.engadget.com/home/smart...bring-art-to-your-home-170016899.html?src=rss
