Rode has announced the Wireless Micro, a two-mic kit with a smartphone receiver and charging case that costs just $149. The idea is to help TikTok and other creators capture much better-quality audio than their smartphone's microphone can offer.
The receiver unit connects to the bottom of your smartphone via a USB-C or lightning port. Meanwhile, the microphones (aka transmitters) attach to the subject via integrated clips or magnetic attachments, then capture what Rode calls "pristine" quality sound. Specifically, they offer a 20-20 kHz frequency range and 73 dB signal-to-noise ratio, with a transmission range around 330 feet.
Rode
To use it, simply connect the receiver to your iOS or Android device and it will take over as the system microphone. From there, everything is automatic, as the transmitter mics are automatically paired to the receiver and sound will be captured to your camera app of choice. Levels are automatically controlled with the company's GainAssist technology.
The omnidirectional transmitters weigh just 12 grams (0.42 ounces) and are tiny enough to be discreet when clipped onto your subject. The built-in microphones use what Rode calls "acoustic chambers" with a patent-pending design. That supposedly lets you capture clear and intelligible audio while reducing wind noise, though a pair of windmuffs is also included in the kit.
Rode
The Wireless Micro also includes a charging case that delivers two full recharges for up to 18 hours of battery life, while giving you a secure place to store everything.
There are a few things missing, though. You can't connect an external mic to the transmitters, unlike with other Rode wireless mics or the DJI Mic 2. There's no smartphone Bluetooth capability, and it doesn't offer a 3.5mm connection for cameras — a feature that will supposedly exist on the rumored DJI Mic Mini. Still, this looks like a great option for creators who primarily use smartphones. It's now available in a two mic kit with a receiver and charging case for $150.
This article originally appeared on Engadget at https://www.engadget.com/audio/rode...d-for-smartphone-users-150040695.html?src=rss
Rode
Rode
