Image: SharkNinja
This Ninja Luxe Cafe claims to be the only “no guesswork” semi-automatic espresso machine that also comes with the ability to make drip coffee and cold brew. Using “Barista Assist Technology,” it can suggest what grind size to set based on the drink you’re trying to make, ideally saving you a few minutes and some stress in getting your fresh roasted beans dialed in right for an espresso.
It will also weigh the ground coffee coming out, so you don’t have to rely on inconsistent timed grinds. Afterward, you’ll press the grounds with an assisted tamper, then, like most other espresso machines, manually install the portafilter in the group head.
The Luxe Cafe is not a fully automatic espresso machine like this $1,999 one from Bosch that can...
Continue reading…
