Higher quality DisplayPort connection guaranteed
Image: Silkland
Your monitor may have come with a cable—but if you want the absolute best performance from your PC and display, you need a cable built to handle today’s cutting-edge tech.
That’s where the premium-build Silkland 80Gbps DisplayPort 2.1 Cable comes in. As the world’s first fully VESA-certified 2m DP80 cable available on Amazon, it delivers next-level reliability and performance that generic or low-quality cables simply can’t match.
DP80-certified DisplayPort cables are specially constructed to ensure the best performance for high-bandwidth applications, addressing the limitations of traditional cables that can’t support high resolutions (such as 8K@60Hz or 4K@240Hz) or are incompatible with the latest graphics cards and monitors.
You don’t get a “better” picture or other incremental improvements with a more expensive DisplayPort cable, but a poor-quality cable can lead to data errors and corruption of the video or audio data and will likely be less reliable over the long term.
Silkland
The ultra-high bandwidth 80Gbps DisplayPort 2.1 Cable from Silkland supports 80Gbps bandwidth and clarity, delivering uncompressed 8K@60Hz, 4K@240Hz and 2K@540Hz, with DSC enabling up to 16K@60Hz and 8K@240Hz for ultra-high-resolution visuals.
10% off for PCWORLD readers on Amazon
It’s optimized for high-end gaming—eliminating lag, screen tearing, and flickering, guaranteeing stable, seamless data transfer with multi-monitor support for an immersive experience. Enjoy buttery-smooth gameplay with full support for multi-monitor setups, G-Sync, and FreeSync.
It is important to avoid low-quality DisplayPort cables to prevent unexpected video or audio problems, and even system boot issues.
You know you can trust the Silkland cable as it’s the world’s first 2m DP80 cable that’s fully certified by the experts at VESA to be affordably available on Amazon. VESA certification means you know the cable meets the highest industry standards for performance and reliability. The Silkland cable comes with a 24-month warranty and fast technical assistance to ensure a worry-free purchase.
Silkland
Maximizing the ultra-high resolution, bandwidth, and refresh rate advantages of DisplayPort 2.1 (80Gbps), the Silkland DisplayPort Cable minimizes signal interference to prevent screen flickering or blackouts. Its 24K gold-plated connectors ensure corrosion resistance and stable transmission, while the dual-layer tinplate shielding provides extra protection for efficient data transfer.
This premium long-lasting cable is incredibly tough yet super flexible. Unlike ordinary PVC cables, this cable’s aluminum alloy housing and braided exterior provide superior durability and flexibility, ensuring easier and neater cable management. It can hold up to 10kg and has been tested through over 15,000 bending tests.
Silkland
While this version of DisplayPort is the latest version that delivers up to 270% greater bandwidth compared to DisplayPort 1.2, higher resolutions, and faster refresh rates, it’s fully backwards compatible so is ready for both your current setup and future proofs you for your next upgrade.
The Silkland 80Gbps DisplayPort 2.1 Cable is VESA certified in four lengths: 1.6ft ($21.99), 3.3ft ($23.99), 5ft ($23.99), and 6.6ft ($23.99). Longer options are also available—10ft ($39.99) and 16.5ft ($49.99). All are available now on Amazon: PCWorld readers can get an extra 10% off the DP80 6.6ft (2m) Cable by using the code PCWDP80S.
At these affordable prices you need to be sure that the cable is top notch and able to unleash the full potential of your monitor and GPU. Fully VESA certified, the Silkland 80Gbps DisplayPort 2.1 Cable can be trusted to deliver uncompromising performance, durability, and reliability—at an affordable price.
Get 10% off the Silkland 80Gbps DisplayPort 2.1 Cable
View 10% Off Deal
Silkland
Image: Silkland
Silkland
Silkland
Silkland
View 10% Off Deal
Silkland
