 - 23 Август 2023
	Speech to Text to Speech with AI Using Python — a How-To Guide
How to Create a Speech-to-Text-to-Speech Program
Image by Mariia Shalabaieva from unsplash
It’s been exactly a decade since I started attending GeekCon (yes, a geeks’ conference ?) — a weekend-long hackathon-makeathon in which all projects must be useless and just-for-fun, and this year there was an exciting twist: all projects were required to incorporate some form of AI.
My group’s project was a speech-to-text-to-speech game, and here’s how it works: the user selects a character to talk to, and then verbally expresses anything they’d like to the character. This spoken input is transcribed and sent to ChatGPT, which responds as if it were the character. The response is then read aloud using text-to-speech technology.
Now that the game is up and running, bringing laughs and fun, I’ve crafted this how-to guide to help you create a similar game on your own. Throughout the article, we’ll also explore the various considerations and decisions we made during the hackathon.
Want to see the full code? Here is the link!
The Program’s Flow
Once the server is running, the user will hear the app “talking”, prompting them to choose the figure they want to talk to and start conversing with their selected character. Each time they want to talk out loud — they should press and hold a key on the keyboard while talking. When they finish talking (and release the key), their recording will be transcribed by Whisper (a text-to-speech model by OpenAI), and the transcription will be sent to ChatGPT for a response. The response will be read out loud using a text-to-speech library, and the user will hear it.
Implementation
Disclaimer
Note: The project was developed on a Windows operating system and incorporates the pyttsx3 library, which lacks compatibility with M1/M2 chips. As pyttsx3 is not supported on Mac, users are advised to explore alternative text-to-speech libraries that are compatible with macOS environments.
Openai Integration
I utilized two OpenAI models: Whisper, for speech-to-text transcription, and the ChatGPT API for generating responses based on the user’s input to their selected figure. While doing so costs money, the pricing model is very cheap, and personally, my bill is still under $1 for all my usage. To get started, I made an initial deposit of $5, and to date, I have not exhausted this deposit, and this initial deposit won’t expire until a year from now.
I’m not receiving any payment or benefits from OpenAI for writing this.
Once you get your OpenAI API key — set it as an environment variable to use upon making the API calls. Make sure not to push your key to the codebase or any public location, and not to share it unsafely.
Speech to Text — Create Transcription
The implementation of the speech-to-text feature was achieved using Whisper, an OpenAI model.
Below is the code snippet for the function responsible for transcription:
async def get_transcript(audio_file_path: str,
text_to_draw_while_waiting: str) -> Optional[str]:
openai.api_key = os.environ.get("OPENAI_API_KEY")
audio_file = open(audio_file_path, "rb")
transcript = None
async def transcribe_audio() -> None:
nonlocal transcript
try:
response = openai.Audio.transcribe(
model="whisper-1", file=audio_file, language="en")
transcript = response.get("text")
except Exception as e:
print(e)
draw_thread = Thread(target=print_text_while_waiting_for_transcription(
text_to_draw_while_waiting))
draw_thread.start()
transcription_task = asyncio.create_task(transcribe_audio())
await transcription_task
if transcript is None:
print("Transcription not available within the specified timeout.")
return transcript
This function is marked as asynchronous (async) since the API call may take some time to return a response, and we await it to ensure that the program doesn’t progress until the response is received.
As you can see, the get_transcript function also invokes the print_text_while_waiting_for_transcription function. Why? Since obtaining the transcription is a time-consuming task, we wanted to keep the user informed that the program is actively processing their request and not stuck or unresponsive. As a result, this text is gradually printed as the user awaits the next step.
String Matching Using FuzzyWuzzy for Text Comparison
After transcribing the speech into text, we either utilized it as is, or attempted to compare it with an existing string.
The comparison use cases were: selecting a figure from a predefined list of options, deciding whether to continue playing or not, and when opting to continue - deciding whether to choose a new figure or stick with the current one.
In such cases, we wanted to compare the user’s spoken input transcription with the options in our lists, and therefore we decided to use the FuzzyWuzzy library for string matching.
This enabled choosing the closest option from the list, as long as the matching score exceeded a predefined threshold.
Here’s a snippet of our function:
def detect_chosen_option_from_transcript(
transcript: str, options: List[str]) -> str:
best_match_score = 0
best_match = ""
for option in options:
score = fuzz.token_set_ratio(transcript.lower(), option.lower())
if score > best_match_score:
best_match_score = score
best_match = option
if best_match_score >= 70:
return best_match
else:
return ""
If you want to learn more about the FuzzyWuzzy library and its functions — you can check out an article I wrote about it here.
Get ChatGPT Response
Once we have the transcription, we can send it over to ChatGPT to get a response.
For each ChatGPT request, we added a prompt asking for a short and funny response. We also told ChatGPT which figure to pretend to be.
So our function looked as follows:
def get_gpt_response(transcript: str, chosen_figure: str) -> str:
system_instructions = get_system_instructions(chosen_figure)
try:
return make_openai_request(
system_instructions=system_instructions,
user_question=transcript).choices[0].message["content"]
logging.error(f"could not get ChatGPT response. error: {str(e)}")
raise e
and the system instructions looked as follows:
def get_system_instructions(figure: str) -> str:
return f"You provide funny and short answers. You are: {figure}"
Text to Speech
For the text-to-speech part, we opted for a Python library called pyttsx3. This choice was not only straightforward to implement but also offered several additional advantages. It’s free of charge, provides two voice options — male and female — and allows you to select the speaking rate in words per minute (speech speed).
When a user starts the game, they pick a character from a predefined list of options. If we couldn’t find a match for what they said within our list, we’d randomly select a character from our “fallback figures” list. In both lists, each character was associated with a gender, so our text-to-speech function also received the voice ID corresponding to the selected gender.
This is what our text-to-speech function looked like:
def text_to_speech(text: str, gender: str = Gender.FEMALE.value) -> None:
engine = pyttsx3.init()
engine.setProperty("rate", WORDS_PER_MINUTE_RATE)
voices = engine.getProperty("voices")
voice_id = voices[0].id if gender == "male" else voices[1].id
engine.setProperty("voice", voice_id)
engine.say(text)
engine.runAndWait()
The Main Flow
Now that we’ve more or less got all the pieces of our app in place, it’s time to dive into the gameplay! The main flow is outlined below. You might notice some functions we haven’t delved into (e.g. choose_figure, play_round), but you can explore the full code by checking out the repo. Eventually, most of these higher-level functions tie into the internal functions we’ve covered above.
Here’s a snippet of the main game flow:
import asyncio
from src.handle_transcript import text_to_speech
from src.main_flow_helpers import choose_figure, start, play_round, \
is_another_round
def farewell() -> None:
farewell_message = "It was great having you here, " \
"hope to see you again soon!"
print(f"\n{farewell_message}")
text_to_speech(farewell_message)
async def get_round_settings(figure: str) -> dict:
new_round_choice = await is_another_round()
if new_round_choice == "new figure":
return {"figure": "", "another_round": True}
elif new_round_choice == "no":
return {"figure": "", "another_round": False}
elif new_round_choice == "yes":
return {"figure": figure, "another_round": True}
async def main():
start()
another_round = True
figure = ""
while True:
if not figure:
figure = await choose_figure()
while another_round:
await play_round(chosen_figure=figure)
user_choices = await get_round_settings(figure)
figure, another_round = \
user_choices.get("figure"), user_choices.get("another_round")
if not figure:
break
if another_round is False:
farewell()
break
if __name__ == "__main__":
asyncio.run(main())
The Roads Not Taken
We had several ideas in mind that we didn’t get to implement during the hackathon. This was either because we did not find an API we were satisfied with during that weekend, or due to the time constraints preventing us from developing certain features. These are the paths we didn’t take for this project:
Matching the Response Voice with the Chosen Figure’s “Actual” Voice
Imagine if the user chose to talk to Shrek, Trump, or Oprah Winfrey. We wanted our text-to-speech library or API to articulate responses using voices that matched the chosen figure. However, we couldn’t find a library or API during the hackathon that offered this feature at a reasonable cost. We’re still open to suggestions if you have any =)
Let the Users Talk to “Themselves”
Another intriguing idea was to prompt users to provide a vocal sample of themselves speaking. We would then train a model using this sample and have all the responses generated by ChatGPT read aloud in the user’s own voice. In this scenario, the user could choose the tone of the responses (affirmative and supportive, sarcastic, angry, etc.), but the voice would closely resemble that of the user. However, we couldn’t find an API that supported this within the constraints of the hackathon.
Adding a Frontend to Our Application
Our initial plan was to include a frontend component in our application. However, due to a last-minute change in the number of participants in our group, we decided to prioritize the backend development. As a result, the application currently runs on the command line interface (CLI) and doesn’t have frontend side.
Additional Improvements We Have In Mind
Latency is what bothers me most at the moment.
There are several components in the flow with a relatively high latency that in my opinion slightly harm the user experience. For example: the time it takes from finishing providing the audio input and receiving a transcription, and the time it takes since the user presses a button until the system actually starts recording the audio. So if the user starts talking right after pressing the key — there will be at least one second of audio that won’t be recorded due to this lag.
Link to the Repo & Credits
Want to see the whole project? It’s right here!
Also, warm credit goes to Lior Yardeni, my hackathon partner with whom I created this game.
Summing Up
In this article, we learned how to create a speech-to-text-to-speech game using Python, and intertwined it with AI. We’ve used the Whisper model by OpenAI for speech recognition, played around with the FuzzyWuzzy library for text matching, tapped into ChatGPT’s conversational magic via their developer API, and brought it all to life with pyttsx3 for text-to-speech. While OpenAI’s services (Whisper and ChatGPT for developers) do come with a modest cost, it’s budget-friendly.
We hope you’ve found this guide enlightening and that it’s motivating you to embark on your projects.
Cheers to coding and fun! ?
Speech to Text to Speech with AI Using Python — a How-To Guide was originally published in Towards Data Science on Medium, where people are continuing the conversation by highlighting and responding to this story.
The Program’s Flow
Implementation
Disclaimer
Openai Integration
transcript = None
nonlocal transcript
try:
print(e)
draw_thread.start()
return transcript
best_match = ""
best_match = option
return best_match
else:
return ""
try:
raise e
Text to Speech
engine.say(text)
engine.runAndWait()
The Main Flow
import asyncio
is_another_round
async def main():
start()
figure = ""
while True:
if not figure:
if not figure:
break
farewell()
break
asyncio.run(main())
The Roads Not Taken
Summing Up
