Обзор Swapping between hard floor and carpet cleaning has never been easier with the Dreame H15 Pro CarpetFlex
Обзор
15 Февраль 2018
Robot vacuums are becoming incredibly capable, but there’s something satisfying about the extra reach and deeper clean you can manage when using a handheld device. This doesn’t mean you have to pull out your broom, mop, and bucket, though, with the current generation of wet-dry handheld vacuums packed with as much tech and more power than their robot counterparts.
And now, with the Dreame H15 Pro CarpetFlex, the company’s first dual brush wet-dry vacuum system, you don’t have to worry about needing multiple devices to manage carpets and hard floors. And it cleans itself too! Here’s everything you need to know.
Clean wet and dry messes in one go
While you could use other wet-dry vacuums on carpets as long as the mop mode and water are turned off, it’s always a challenge to get the perfect carpet cleaning because of the singular brush type that’s better suited for hard floors. This is the biggest pain point that the Dreame H15 Pro CarpetFlex addresses, with a simple but innovative solution.
The vacuum comes with a dual-brush system, allowing you to quickly and easily switch between a carpet brush and a hard floor brush. The carpet brush can comfortably manage short- and long-pile carpets and rugs, picking up any hair, pet fur, or embedded debris with ease.
And when you switch to the hard floor brush, you’ll get the convenience of both vacuuming and mopping in one pass on hardwood, tile, and other floor types. The vacuum automatically detects the brush type and adjusts the cleaning mode for optimal performance.
Say goodbye to your dust allergies with the MistLock Dust Control System
If you or someone in your family has a dust allergy, which includes more than 20 million Americans, according to Dreame, you probably know how sneezing can kick in almost immediately when cleaning dusty areas. And for some, the reactions can be even more serious. That’s why the H15 Pro CarpetFlex’s MistLock Dust Control System is such a helpful tool.
The MistLock system, as the name suggests, uses ultra-fine water droplets to catch dust particles right when they enter the inlet. Then, powerful suction pulls these particles into the water tank, turning them into damp clusters that stop dust from escaping through the motor exhaust.
This clever innovation reduces secondary dust pollution, making it a real game-changer for pet owners, families with kids, or anyone with sensitivities. It helps keep the air cleaner and your floors spotless, all at the same time.
Once you’re done, it will clean itself with heat power
If you were worried that you now had two different types of brushes to clean and maintain, the fantastic news is that the Dreame H15 Pro CarpetFlex will do that for you. The vacuum’s base station automatically detects the type of brush in use and sets the appropriate cleaning mode.
For the hard floor brush, that means the ThermoTub™ Hot Water Self-Cleaning system. It powerfully flushes the roller with 212°F (100°C) water to instantly dissolve tough grease and grime. This is followed by a complete rinse to wash away any residue and prevent odor buildup. Finally, the hot air fast-drying feature circulates air at 194°F (90°C) throughout the entire device, covering everything from the brush to the pipes and filter.
And when you’re cleaning the carpet brush, the base station uses cold water to flush out fuzz, lint, and debris from the cover, inner walls, and air inlet to prevent blockages and maintain suction power.
A single tap is all you need to ensure clean and pristine brushes that are ready for the next pass, while maintaining a mildew- and odor-free vacuum overall.
Powerful performance with effortless glide
You get a whopping 23,000 Pa of suction power, ensuring that the H15 Pro CarpetFlex can handle everything from everyday spills and messes to deeply embedded debris in carpets. And with 5-channel RGB detection, it efficiently differentiates between mess types in real-time.
With the mop rotating at 480RPM, the vacuum also actively rinses its hard floor brush with fresh water, preventing dirty water from being dragged around. Whether it’s everyday dust and crumbs, liquid spills, or tough stains, the H15 Pro CarpetFlex can handle it all.
Its TangleCut™ 2.0 system is specifically designed to handle dense pet fur. It features 15% denser comb teeth, allowing the vacuum to capture and cut hair and pet fur faster and more precisely, making it ideal for families with multiple pets.
It also features a GlideWheel 2.0 that utilizes smart algorithms to control the two rear wheels, ensuring smooth movement on any floor or carpet. It can precisely detect direction, turning, and speed to automatically adjust the push assistance, making for a smooth, easy, and nearly effortless cleaning experience.
The H15 Pro CarpetFlex is one of the most flexible wet dry vacuums we’ve seen, comfortably moving around and reaching the deepest corners with ease. The device can lie flat at 180°, effortlessly gliding into gaps as narrow as 5.5in, ideal for cleaning beneath furniture.
And you don’t have to worry about interrupting your cleaning to charge the device either. In Quiet Mode, you get up to 60 minutes of use, more than enough to cover a little under 3,300 sq. ft. of space in one pass. When you do have to charge, its fast charging capabilities get you back to full in just 3 hours.
Get the Dreame H15 Pro CarpetFlex now!
If you’re someone who loves the convenience of a handheld cleaning system but appreciates all the tech you can get, the Dreame H15 Pro CarpetFlex is the perfect fit. Handling everything from short to high-pile carpets to all kinds of hard floor types, the vacuum is packed with features to help you achieve the perfect deep clean every time. And once you’re done, it will even wash and maintain the brushes for you. The Dreame H15 Pro CarpetFlex is priced at $699.99
