Many PC owners wonder when it might be the best time to upgrade parts of their setup that are perhaps getting a little long in the tooth. The answer to that is relatively simple: whenever there’s a good sale. A bunch of Samsung monitors are currently up to 33 percent off over at Amazon. Among them is the 27-inch Samsung Smart Monitor M8, which has dropped to a record low of $480. That’s 26 percent off the regular price.
The M8 can double as a 4K streaming TV, since it has native support for apps including Netflix, Prime Video and Disney+. Through Samsung TV Plus, you can access a selection of free live and on-demand programming. In addition, you'll be able to stream games from the likes of Xbox Cloud Gaming and NVIDIA GeForce Now. They should run fairly smoothly too, thanks to the 60Hz refresh rate.
Of course, you can use the Smart Monitor M8 for productivity too. For tasks such as web browsing and document editing, you won't even need to hook up a PC. The M8 offers options to connect to another PC remotely, access the Microsoft Office 365 suite and even use the desktop mode of Samsung mobile devices thanks to the DeX feature. There's a built-in camera for video calls too. Moreover, you can use the M8 to control various smart home devices.
In case you don't need all those bells and whistles and you're just looking for a solid monitor that can get the job done on a tighter budget, a 22-inch 1080p model may do the trick. A T350 Series monitor has dropped by a third to $100, which is almost a record low for that model.
It has a decent 75Hz refresh rate and an IPS panel that Samsung claims will support a wide variety of viewing angles. FreeSync will help reduce screen tearing if you have a compatible AMD CPU, while the response time of 5ms isn't too bad for gaming.
Follow @EngadgetDeals on Twitter and subscribe to the Engadget Deals newsletter for the latest tech deals and buying advice.
This article originally appeared on Engadget at https://www.engadget.com/the-27-inc...er-than-ever-right-now-153331058.html?src=rss
