The Anker Nebula Solar HD portable projector is on sale at Amazon for $250. That matches a previous low and represents a 46 percent discount off the current $460 list price. Wshen it first came out in 2021, it went for $600. We give the Nebula Solar a shout out in our buyer's guide to projectors as a notable budget option, noting that you get a lot of features for the price.
It's a 1080p HD projector that emits 400 lumens for reasonably bright outdoor use. The battery is included, which isn't always the case with portable projectors, so that's another relevant savings. You'll get up to three hours of play from a charge (depending on how bright you set the output) and sound comes courtesy of dual three-watt speakers with support for Dolby Digital Plus.
Android TV is preloaded and the projector is Wi-Fi enabled to access that content. You can also connect via HDMI, USB or Bluetooth, and it can mirror content from your phone using Miracast. Since it's a projector, the screen size depends on how far away you place it from the wall or other projection surface. This one can deliver up to 120 inches of movie or TV visuals and has a built-in stand to help you adjust the angle.
Of course, as a portable projector, the Nebula Solar isn't going to be as bright as its corded cousins, but if you want to try out watching a movie under the stars once the weather warms up, this is a pretty inexpensive way to do it.
Follow @EngadgetDeals on Twitter and subscribe to the Engadget Deals newsletter for the latest tech deals and buying advice.
This article originally appeared on Engadget at https://www.engadget.com/ankers-neb...rly-half-off-right-now-173027922.html?src=rss
