Elgato’s going all-in on HDMI 2.1. The company just announced a pair of capture cards that support the latest display technology specification. The 4K X and 4K Pro offer true HDR10 support, USB 3.2 connectivity, VRR and can capture 4K gameplay at 144fps.
Also, this card actually works with newer USB-C iPad models. This is the first time a capture card has ever offered native support for iPads, according to Elgato and parent company Corsair. The 4K X is compatible with both Windows and Mac computers and captures 4K gameplay at 144fps, you need a native display that supports these metrics. Otherwise, you’ll capture 4K at 120fps. You shouldn’t get any screen tearing with this device, due to the magic of HDMI 2.1.
Also, this card actually works with newer USB-C iPad models. This is the first time a capture card has ever offered native support for iPads, according to Elgato and parent company Corsair. The 4K X is compatible with both Windows and Mac computers.
The 4K Pro goes even further. This is a capture card in the traditional sense, as it resides inside of your PC. You get all of the features provided by the 4K X, but the passthrough spec bumps up to 8K and 60fps. Elgato claims this card will transform “your high-end single or dual-PC setup into a live-streaming powerhouse.”
To that end, the 4K Pro offers low-latency passthrough support up to 240fps in 4K, all while capturing 4K content at 1080p and 240fps. As you can see, this card boasts a wide range of specs, so you can adjust to find the best fit for your live-streaming needs. The card also integrates with the company’s Multi App tool, allowing you to send capture feeds to multiple apps at the same time. Elgato gives an example of recording raw gameplay while streaming simultaneously in OBS, Discord and Zoom. The 4K Pro is only compatible with Windows machines via a PCIe 2.0 x4 connection.
To that end, both cards work with most popular broadcast apps, including OBS Studio, Twitch Studio, Streamlabs Desktop, vMix and others. You also get access to the company’s capture management app, which exports content as AAF files for editing in Adobe Premiere, Vegas Pro and related software.
Both of these capture cards are available right now. The portable 4K X costs $230, while the PCIe-adjacent 4K Pro costs $280. In related news, Samsung just inserted HDMI 2.1 support into its Q990D soundbar.
This article originally appeared on Engadget at https://www.engadget.com/elgato-int...-hdmi-21-capture-cards-174046239.html?src=rss
